2003 Inherited Green Suburban
rzabel
Redmond, Oregon
I've been over at some of the 'suburban' sites and didn't get a good vibe. So, I'm here to see if the Tahoe/Yukon folks would be willing to help me sort things out.
My dad died.
I now have his 2003 Green Suburban.
My current problems:
1. Rear power windows on both sides do not go down or up- local switch or driver switch makes no difference. Am going to try bypassing with portable battery tomorrow.
2. A/C controls in the overhead area kept falling out so my dad disconnected the controls and they are sitting in a basket in the backseat. I need a way to keep them from 'walking' out of the plastic housing in the ceiling. Dad's solution of black mastic just made a huge mess and when it heats up in the summer the controls just vibrate back out of the housing.
3. Packrats completely filled the blower motor for the A/C with acorns. Gross! I finally got blower motor out and all acorns removed, but there is a 'thrum' sound when I have the blower on setting 3-4-or 5. At least it is cooling and blowing air now.
4. My dad backed into a tree and crushed a 1 foot by 10 inch area just outside the rear passenger side backup light. I look like I'm an idiot driver and folks comment on my 'beauty mark'.
5. Both front seats have cushion showing through the busted leather. Dad's solution was duct tape -- in silver so it would sort of match the gray leather. (head smack- what was he thinking?)
What I've fixed:
1. A/C blows cold air!!! Added R134 and cleaned the acorns out of the blower motor.
2. Rats had chewed some wiring on fuel injector. I went dumpster diving at the local repair shop and clipped a couple of replacement injectors from an old harness. Spliced in a new injector. Works fine and I have a backup if needed.
3. Rats also chewed the ground wire from the rear of the motor up to the body ground location. I added a new ground wire from the engine block (rear) up to the front of the cowling. Couldn't get my hands into where the old wire was grounding on the body.
4. Had a mechanic drain the gas tank and replace the sending unit in the gas tank as well as the fuel filter. The tank was completely full of gas. Saved the gas and it started up.
5. Spent 21 days chasing wiring gremlin that was causing anti-theft device to prevent start-up. On day 22 my anti-theft by-pass module, wire replacement, and ground wire cleanup allowed me to start the beast with the key again.
I'll get pictures of the vehicle and more info on the details of the engine if that's helpful.
If this isn't the type of forum where I can get basic questions answered, just say and I'll go elsewhere.
I already know I'm a girl.
I already know I'm a Texan.
I already know I am asking newbie/basic questions.
I already know I could replace this with a newer vehicle.. but this is the last thing I have of my dad's (other than his old dog).
I'd appreciate any guidance/recommendations.
JW
Sorry for your loss and welcome to the site. Sounds like you've done a pretty good job already for a newbie. I've been on this site for awhile, but don't post much, because I don't know much. I have found this site and the people on it to be extremely helpful. I'm not that mechanically inclined, so I sort through the info and only tackle the easy items myself. However, even when I hire out the more challenging work, it's good to have some knowledge on your side.
I have a 2003 Yukon XL and have experienced some of the same things you have. Here are a few of my experiences:
After a recent camping trip, I heard a thumping noise coming from the A/C blower motor. It was still working and I needed the A/C, so it was a few days before I had a chance to look at it. When I opened it up, I found a dead mouse that had its teeth sunk into one of the fan blades and was plastered to the side of the fan. What a ride!! After removal, my fan is still a little louder than it used to be, so I'll open it back up for a better cleaning as was suggested here.
When I purchased the truck, the drivers side seat was worn with the cushion showing too. I bought a replacement bottom cover and cushion only and replaced them. The online company I purchased it from had really good youtube videos to show how to do it. It looks like new, but it was leather and fairly expensive. I replaced the seat heater element at the time too, since it wasn't working and I read that was common. That didn't fix it though, so I have a little more work to do there.
Electrical gremlins are common and so frustrating! I ended up buying a jump pack and installing a second battery because I couldn't find the parasitic draw on my rig. Obviously, that didn't solve the problem, but kept me from getting stranded. I didn't have 21 days to look for the problem, so I finally took it to someone that knows the electrical systems on these vehicles very well and told them I would pay them to just go through it, removing anything that didn't belong and fixing all the grounds. They gave me back a large cardboard box full of wires and devices and I haven't had a problem since. It had an aftermarket remote start on it that I didn't even know about. Those are notorius for problems.
Good luck!!
J
justwondering
Amazing!
Feels like I have found a new home....
Thanks so much for the recommendations.
I have done the following:
1. Rear Windows Wont Lower
Checked to make sure the child safety lockout was off. No difference.
Pulled the driver-side controls, removed the bezel, pried open the housing, pulled it apart and put electric cleaner on the contacts. Put it all back together. No difference.
Plan to go to the junk yard to see if there is one there. Will take my battery, jump it and see if it works prior to buying it. I'm also leaning with the 'bad' switch or 'bad' ground as the culprit.
2. Overhead AC Controls in Backseat area
Tried the double-stick tape, heavy duty version. Did not work for long. Heat did it in.
Will check for another unit at the junk yard, paying attention to the 'broken clip' possibility.
3. Blower Motor
Run the motor only on 1-2-or 3 until I can set up a box fan to blow on me while I pull it again to re-clean it. Could be I should have put some lithium on it or lubricate it and make sure its squeaky clean. Weather is supposed to be better for the next 10 days.
4. Dent in rear quarter panel
No decent repair places near where I live... at least not that I've heard. So I'm thinking to clean it up, prep the metal with some primer and let it go for now. If I get some time, I'll just paint a big band-aid on it and enjoy the looks from folks.
5. Front cushions
I'm adding a towel to cover the front seat bottom until this winter. If I'm going to replace the cushion/cover, then I'll research adding in a front seat heater as well.
Do I really get static for being female?
Yes. Some of the forums out there are not so tolerant.
What type of dog is it?
Nearly 18 year old Australian shepherd, border collie mix. Blind (cataracts) and deaf (old age). Unless its time to eat, she mainly just sleeps the day away. Hates to have her nails trimmed, but loves to have her ears cleaned.
I'll post some pictures of things and do a more thorough job of putting the specifics of my vehicle in my signature.
wjburken
Eastern Iowa
Welcome to the forum from Iowa.
I would also like to extend my condolences. I lost my mother back in April.
Sounds like you have been given some good direction on your initial list of to-dos.
We like pictures so would love to see some pictures of your Suburban.
ehernande86
