2003 Tahoe dashboard paint peeling
JayXSP
Wallingford, CT
Thanks. The trick is to feather out the edges first with 600 grit paper. Some say you need to adhesion promote the plastic first... (i do custom paint/airbrushing for a living just for reference) and my experience if you just clean the surface well with a degreaser you won't have any adhesion issues. I believe the Color coat has a adhesion promoter already in the paint which helps.
el_flores
You do that all without having to remove your dash? I'm contemplating doing this but I'm debating on whether I should remove my dash to do it or just leave it in?
JayXSP
Wallingford, CT
I removed the bezel. And taped up the vents/radio areas. If you know how to spray you shouldn't have an issue. If u get overspray on the window it'll come off with a razor. I paint for a living so it was a pretty simple job.
Pachanga02
Ny
Wow that came out looking great Jay. I may have to look into this SEM paint for mine as it has a few wear spots.
el_flores
Jay, did you use SEM Graphite #15303 Color Coat to match the GM Charcoal dash?
chaser
