2003 vortec 6.0 - fuel pressure problems
W
westman995
How likely is that, with a brand new ac delco pump?
I swapped two injectors around and the misfire seemed to follow it so looks like it need's some injectors.. when I changed the pump the tank had dirt n shit in it so I cleaned it all out n put a new filter on it.
Injectors looked dirty when I took them out
01ssreda4
My original post was before I replaced the cheap pump with the ac delco pump. The pressure is now higher at around 48 while running if I recall.
Weird thing is if I turn the key on it jumps up to 58 or so then drops right down like 10 psi and then it'll slowly bleed off from there.
I ended up ordering a regulator so I'll see what happens after that
This is not within spec per the service manual. I know this as fact because my truck had the same issue.
W
westman995
Well what else can cause the low pressure? I put a brand new ac delco pump in it and itsee better than it was but still not very high.
I need to get a new hose for my fuel pressure tester cuz the pin thing fell out of the end of it
2012z61
