If I were not already bald, I'd be pulling my hair out at this point.
2003 Yukon SLT 2WD
295K miles
I have been dealing with a coolant leak / disappearing coolant since winter 2016. I found that the heater hose connector was leaking coolant there. It is notorious for happening after a while. I swapped both the black and the white one out. All seemed to be well. The replacement failed in fabulous fashion (ie. the leak was even worse this time!) in about 3 or 4 months. I've replaced it again. Seems to be going strong. No leaking.
However, my coolant was still disappearing slowly but surely! I have seen no leaks or puddles. Could not figure it out.
I did not smell any coolant in the exhaust. This past week I did begin to smell coolant from the engine bay.
My mind went straight to "it must be the water pump.". Afterall, it's the original, and it just seemed to make sense. So I swapped out the water pump last week right before going on a 450+ mile trip. I get to my destination and I get a "Low Coolant Level" error on the dash. I checked the connections to the new water pump for leaks. Nothing. I checked the reservoir tank for leaks. Nothing. I did not tear the panels and covers off yet to get back into the engine to take a close look at the gaskets for the water pump yet, but from what I can see they seems to be fine. I torqued the mounting bolts for the pump to 22Ft-lbs. Smh.... I'm at a loss here.
Has anybody experienced this that can offer some insight as to what is going wrong here?
2003 Yukon SLT 2WD
295K miles
