2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Hope you get it broken loose man. I hate when things don't go as planned. Sometimes, its best to take a break for a bit and then bam, it works good.
That big boy milwaukee should do the trick...if not, put some more d*ck into it. You'll get er
If the Milwaukee doesn't do it then it's the first time it has been unsuccessful. I think she needs more juice and it will do it, I did spray it with creep oil so it should help.
pwtr02ss
Tennessee
The milwaukee would not break the manifold to y-pipe bolts loose on my avalanche. Had to get my buddy Casey over there on a 3' breaker bar to get them loose. I put everything I had on it. Took his big ass to get it done tho. It was on an extension though
pwtr02ss
Tennessee
I used the handle for my jack on the end of my 3’ Gear Wrench monster ratchet and put the truck in gear. I was running out of umpf and I’m 6’4” 215#. Worst case scenario I go rent a 1” two handed corded impact from some construction site.
Wow.
That mfr is on there
Jacobamers
