Yeah right…”looking into” ….uh huh I understand yep.Right!
This prompted me to reflect upon my adult life and remind myself of all the holes I ever regretted looking in to.
Not sure where you can get one that fast but this is the type I use. It works extremely good, really necessary if you're doing dual springs.
Valve Spring Compressor Tool Kit Set For GM LS LSX Engine 4.8 5.3 6.0 6.2 7.0L | eBay
(2)GM LS series valve spring compressor tool works by using compressed air in the cylinder at TDC, allowing valve springs or seals changes without removing the cylinder heads. Fit For Works on any GM based LS engines: LS1 LS2 LS3 LS4 LS6 LS7 LS9, LSA, LQ4, LQ9, 4.8, 5.3, 6.0, 6.2, and 7.0.www.ebay.com
You're a BEAST!@iamdub I forgot to credit you with making me first start googling oil pump porting yours looked great which led to this I just didn’t feel like doing the inlet I think it looks okay from the factory.
I did get the motor torn down and everything looks great so far except I broke both spring compressor tools I had. I’m not sure if I was using them wrong or I’m just an ape, anyone have a better suggestion I can get in 3-5days?
Lmao I did all that in about 3 hours with a buddy who’s got five broken vertebrae just chit chatting with me. Non of it would be possible without a good knowledge of these trucks and a few key Milwaukee tools. First is the two M12 ratchets they are amazing time savers, the impact helps a ton as well as the hood light!You're a BEAST!
They make the same design in a double but I find it easier to concentrate on one at a time. Both my trucks have double springs and it takes all my concentration to do one because it’s hard to keep the stem centered as you’re compressing the spring. Vinci High Performance turned me onto this design, the others don’t work well on double springs.Wow that’s cheap, I was looking at a comp cams one for like $100 it’s super nice and does two springs at a time. I think I’ll fork out the money for it since I can get it shipped asap
