WildernessJeep
I have a 2005 Yukon Denali AWD. It won't fuel more than at a sipping pace. It takes about 45 minutes to fill up the entire tank. First, I disconnected the filler tube and ran a piece of bungee through with no issues. Then I came to this forum and discovered the Evap solenoid is a regular (and cheap) fix. Even though I didn't have the common complain of the check engine light, i replaced the Evap solenoid valve with a new AC Delco unit. I'm still having the same problem. I did look inside the filler valve and see a floaty loose plastic thingy, but it seemed to move like it should (should it move?).
Possibly a co-symptom is the fuel gauge is very slow to turn on and show an accurate indication. When I first start the vehicle, it will show "LOW RANGE", then slowly climb over about a 20 minute drive.
Opinions on why this truck won't let me fuel it up?
