2005 GMC Yukon XL Denali New Aftermarket Radio (ATOTO F7) no sound
tooleyondeck
Northwest FL
I was able to retain the bose amp and sub when I installed my aftermarket HU, double check your wiring and make sure everything is color matched. The first thing to check is your +/- for each speaker and go from there.
M
mediom
this might be a dumb question but you said you were able to retain yours. And i was just wondering if you plugged in your amplifer turn on wire because I wasnt able to find one that was communicating with that wire.
That might be your issue. I'd think your amp is getting the signal to turn on--thus no sound.
Fless
Super Moderator
Elev 5,280
I'm certainly no expert on the wiring or interfaces, but if your radio uses the standard wire color codes there apparently should be a Blue/White wire to use to turn on the amp. Does your radio manufacturer include any instructions for installation?
Here's one interface that might be compatible.
PAC RP5 info
tooleyondeck
Northwest FL
PAC RP5 info
^^ This is the module that I installed, and that is how I retained the factory amp + chime module. PAC RP5 GM11
Fless
Super Moderator
Elev 5,280
Same on my '04 and to retain SWC (steering wheel controls). But we don't know what the OP's radio wiring looks like, or what provisions it has available.
tooleyondeck
Northwest FL
most likely you need the PAC module if you have Bose, it is well worth the price for the features you retain.
mattbta
Frisco, TX
Denali Bose is the luxury version with different pinouts/wiring from the "premium" found in Tahoe/Yukon. Make sure the harness is the correct version or the wiring was done correctly.
humphr90
