2005 suburban smoke on startup
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
If the engine is a 5.3 for your 2003 then the part numbers are correct and do cross the same. Like Rocket Man said, it is best to put all rig info in your signature. For instance, there is a choice of the 4.8 and 5.3 engine for your year of rig. See below:
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
BlackedOutHoe
Low & Slow
S. Carolina
See post 52 :Handshake:
Appreciate the willingness to go the extra mile to help, though!
Allthingschevy12
