2005 Tahoe 5.3l engine whine
TailHook
Tattooed Millionaire
Arizona
It's a 2005, so likely has "hydroboost" brake booster?
The three trucks I've had with it have all whined, as the P/S pump provides the boost...
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
OK So i flushed the PS fluid and replaced the belt and idler pulley. Noise remains. I am going to get a mechanics stephascope. Makes the whine with the AC on or off, also in neutral.
Any other ideas of what it could be?
Steering is alot smoother now though!
Did you run the engine with the belt off? If not, you need to in order to isolate the noise.
W
wreedps
So I have put the following new parts on and all the belt squeaks are gone, but the whine is still there. I posted a video, any ideas?
New alternator
new drive belt
new ac belt
new ac tensioner
new belt idler pulley.
---------- Post added at 05:51 PM ---------- Previous post was at 05:51 PM ----------
Well how the hell do I upload the video?
---------- Post added at 05:52 PM ---------- Previous post was at 05:51 PM ----------
https://www.youtube.com/watch?v=uOW_bW3OqbE&feature=youtu.be
afpj
might want to check the water pump. see anything from weep hole? Just a guess since I can't tell quality or location of whine over internet
mattluttrell
I agree on water pump. Don't plan any long trips until you get it fixed too. This might be a bearing failing. When it goes you might be without engine coolant until you get it fixed.
This happened to me.
W
wreedps
Where is the weep hole? I will go check now. I have no leaks btw.
Aaron_L
Arlington, TX
My Suburban was making a noise very similar to that, but I didn't have any voltage or electrical issues. I drove it like that for a year, I figured I'd wait for it to fail but it never did. I even took it on a few trips to Houston (about 4 hours one way). I decided to upgrade my alternator to a higher amperage one & the sound went away. I still have the original alternator, and when you spin it over by hand it makes a noise. I think it's the bearings.
W
wreedps
I have a brand new ACdelco alternator installed. I am beginning to think my noise is now the water pump
MsGofstr
