2005 Tahoe rear coil spring removal???
Blaster.DW
Reading, Pa
So this past weekend I replaced the Auto ride air shocks all around on my Tahoe with Bilstein HDs. Zero issues installing these. Where I did fail was removing the stock rear coil springs to replace them with the Bilstein springs. Here is what I did...jacked Tahoe rear up by center of rear axle. Placed jack stands under frame on sides just in front of bolt to rear section. Then I had rear shock undone and the sway bar link undone. Lowered the the axle until jack was completely down and springs were still solid. I am guessing I need to jack up the rear a bit higher to allow the rear to drop lower or am I missing something? It was getting dark so out of frustration I said another time and kept stock springs in and bolt everything back up. So is that all I need to do is get the rear end up higher? I didn't measure but I am guessing when I put tires back on the tires were about 3 inches of the ground.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
take of tires
disconnect the abs line from the frame on both sides
drop rear end down farther
Your good.
B
Blaster.DW
Reading, Pa
Thanks. That is what I thought. Checked Jack last night too and Max lift is only 15 inches. Guessing that's why I wasn't high enough.
lordmorgul
