SLCHOE
ASE Master Certified + (L1)
There is a harness upgrade (superceeded p/n) for these trucks and this sounds like one of the ones I spent a bit of time on before I called the dealer and found out they had harnesses that would get wet and dirty and cause issues like this. Call the dealer and see if your truck falls within the TSB or post your vin# and I can post the info for you.
---------- Post added at 10:20 PM ---------- Previous post was at 10:16 PM ----------
One other thing is to check the tires sizes. make sure all 4 tires are the same size. Differing tire sizes will cause issues within the 4wd system.
---------- Post added at 10:28 PM ---------- Previous post was at 10:20 PM ----------
15306187 is the part number for the harness for the transfer case speed sensor wire harness update which fails at the connector if it has been disconnected in previuos services. This causes loosenes and thus inaccurate or null readings from the sensor.
This would also cause code C0374
---------- Post added at 10:33 PM ---------- Previous post was at 10:28 PM ----------
Check the transfer case speed sensor wiring. They can get messed up if someone has ever disconnected them. There is an updated harness also from a TSB for this vehicle from GM. The updated harness part number is 15306187. Check the wiring first. If its messed up, fix it.
