2005 Yukon XL - Wifes Daily Driver
mals
Western Mass
Made it a whole 987 miles before my oil pressure gauge crapped out on the reman cluster. Going to call doorman on Monday to see what they're going to do…
Are you sure it is the cluster? One of the ways that an oil pressure sensor failure can show is the 80+ reading when the ignition is in the "run" position with both the engine off or running. I had to swap the one in my '05 Yukon out this summer.
Countryboy07
Countryboy07
Any updates on the instrument cluster?
Not yet, have called and left a message. Going to try again after work.
Didn't think about that... I'll look into it.
Countryboy07
Countryboy07
Brown truck dropped these off today...
Just test fitted them for now, planning on doing a retrofit before I run them.
Countryboy07
Countryboy07
Very nice. Let me know how the light output is. Thinking about going this route as well.
Will do, probably be at least a month before I get all the parts for the retrofit. Ordering a set of adapter plates off GM full-size to make it super simple.
tahoe_highcountry
