2006 Denali Fog Light Retrofit
Shadow711
Ohio
First off, I did a search but didn't anything, but could be a user error lol so if there's a thread on this please point me in the right direction.
anyways....
Has anyone done a retrofit on fog lights? I'm getting ready to do a quad retrofit on the headlights and was curious about doing the fogs too.
ezdaar
Chat Troll
Redneck central, Aka Houston
Retro or replacement?
Lemme show you this my buuuudddiiee!
**** retro a fog!
Btw my old are for sale...
I wanted to share an album on Photobucket with you!
http://s803.photobucket.com/user/ezdaar/library/Denali/Projector fog mods
Sent from my iPad
Shove some 55watt 4500k in them. Make dang shure you use a https://www.theretrofitsource.com/c...-beam-880-881-relay-harness.html#.VkwCIJhb2rU
May i recomend changing from a 88X series bulb to a 9005/6 series. And get the apropriate projector fog light plates.
For one reason. One hid bulb type can be used in your low, high and fogs..
Foook having a 900X up top and a 88X down low.
This allows you to toss a ballast and a bulb in the glove box for emergencys and it works for ALL of your forward lights.
Shadow711
Shadow711
Ohio
Im gonna be buying smoke housings for everything. Denali is black, everything is black. Gonna put mini h1's from TRS in the lows/highs doing a quad. putting in new fogs too. i know the ebay projectors are trash so thought about doing a retro on them too. im replacing all the stock housings
ezdaar
Chat Troll
Good luck retro anything but matchbox projectors into those pos plastic oem denali fogs.
Even with those the projectors withany kind of decent hid power will melt the lenses, they are plastic.
Dump that garbage and go with a pure projector driving light.
Mine are FS and and plug n play.
Im confused,
Do you want smoked lenses or black buckets with your retrofit?
about20ninj45
Im confused,
How muaaaaach fo da lights lol
YukonXL04
The Riverboat
Arlington, TX
What housings are you using to retrofit. Aldo Might I recommend that you do black housings with clear lens vs smoked lens. The smoked lens is gonna kill your light output. Also I would use 2 different projectors. That way one can compliment the other. Also quad minis is gonna have a TON of foreground light. I did TL and Mini quad. The TL's have great distance and high beam, the minis have great up close and foreground light so they compliment each other very well.
Shadow711
Shadow711
Ohio
I was gonna I was planning to use something like these. But instead I should do black housing clear lens?
YukonXL04
The Riverboat
Arlington, TX
Unless you are completely sold on the smoked lens, I would certainly swap to black housing clear lens. In my signature there is a link to my quad build thread. Check it out.
Keep in mind once you have the headlights apart, you can paint them any color you want, so your not just limited to black or chrome.
Shadow711
Shadow711
Ohio
Sweet. I'd looked at the thread before, didn't know that was you. Nice job. It came out great. Reason i was gonna go with Mini h1s is because there is bracket made to fit them onto the denali headlights and it should make it alot easier for that part.... But i may be persuaded otherwise lol. How much light output is lost with smoked lenses. A significant amount?
Judef
