2006 Denali XL trailer brake controller
adventurenali92
Big Bear Lake, ca
Hey guys couldn’t find anything related to the NBS platform on this. I need to pick up a trailer brake controller this week. Is there a controller specific to the 2003-2006 platform? I have the harness that came with my truck for it, now just need to order one. What are you guys using?
Scottydoggs
NJ
trailer brake controllers pretty much are plug and play as long as you have a 7 pin plug out back. read the controllers box make sure its a gm and for your year, it plugs in up under the dash in a block of other plugs. theres a diagram with most controllers and the plugs only gonna fit in one place.
adventurenali92
adventurenali92
Big Bear Lake, ca
So I could search GM controller for my year and it’ll pop up?
PG01
Up here to the right
Your truck came with pigtail, plug that in, buy a good universal controllerand wire it according to instructions....normally its color for colo. go to a place that sells trailers and pick one up.
adventurenali92
adventurenali92
Big Bear Lake, ca
Yeah uh huh, I have no trailer equipment sales in big bear. That would require a trip off the mountain. Was thinking to order one online so I don’t have to spend the gas to drive down the mountain. Was really just looking for someone to chime in with what brand they really like that works well.
PG01
Damn, small town huh? Lol
Scottydoggs
NJ
took a closer look at mine, its a draw tight. have not used it yet myself, and i really think it was a dealer installed item as my hitch looks to never had a receiver inside it.
we got one in the 05 silverado work truck it works as it should no idea on its brand its 5 years old now and i just adjust the brake wheel by feel, never look at at lol
Martinjmpr
Littleton, Co
On my 04 I use a Tekonsha Prodigy P2. You specify the vehicle when you order the controller and they will send you the right wiring. Should plug rignt in. There is a black plastic cover on the floor underneath the brake pedal, you can remove that cover by unscrewing a plastic nut. The truck end of the plastic connector is there, connect that then connect the other end to your brake controller and you're all set.
Only problem is where to put the controller. I put mine on the right side of the steering wheel but it's too close to the steering wheel so I have to push my seat back or my knee will hit it.
adventurenali92
adventurenali92
Big Bear Lake, ca
Awesome thanks for the info!
Mike4400
