2007 Calipers on a 2001
TheAutumnWind
The only problem with the Amazon link is that you have to return a core to get the rebate, core has to be the same brake caliper type you purchased!
You think that they really check? Core charge @ local places don't.
ECLIPSEJ24
ATLANTA GA
What does? Is the rotor actually a larger diameter, hard to tell in your pics? Sorry, I am just trying to figure it out.
The rotors are larger 14 inch but the stock brake set up as a 07 yukon and the kit comes with a larger bracket for the rotors
TheAutumnWind
Ah gotcha. its a 14" vs the stock 13" rotor. I assumed but it was hard to tell in the picture.
Eric70
I'm interested in doing this upgrade, if it's as simple as switching to the newer rotors, calipers, brackets, and pads.
That's the only parts needed, correct? Along with the brake fluid, cleaners, grease, and tools obviously.
Mine is an 02 yukon denali, if that matters.
Thanks
iamrayth
