JochenWoern
Thanks Jason
lol Jacob, drl easy to change?
If spending 1/2 hour taking bumpers on and off is easy then I agree.![]()
1. Daytime running lights are easy to change. I need to the same on mine.
2. Yes it appears yours has the fuel management system. Not sure if they all have it in 07 or not.
The airbag message is most likely one of the sensors unplugged. Mine currently has the same message. I just have not taken the time to track down where it's unplugged at. Most likely on the console side of the passenger seat cuz the wife likes putting stuff down there like umbrellas and stuff.
Nice. Like the color.
And about the service airbag Jacob is probably right I had that message and tracked it down to a disconnected plug under the passengers seat.
Sent from my iPad using Tapatalk
Make sure when taking off the headlight you remove the wheel well cover to remove the bolt underneath the headlight so that doesn't snap off when trying to change out your DRL. Also if you see the V4 to V8 change you definitely have AFM.
