2007 Tahoe 5.3l AFM DOD delete thread
wsteele
The oring I inserted was the green one and it fitted snug enough where it didn't even feel like it had to be bolted on the pump. So I'm hesitant to blame the oring.
On the Rock Auto site, the picture of the Melling pickup tube for the 5.3L 2007 MY with the O-ring on it, the color is red, but I don't think I would put much importance on the picture.
Taheezy_88
Taheezy_88
2:30 oil drops to almost Zero
4:30 minute mark is when the oil stabilizes.
Taheezy_88
Taheezy_88
The Orings I received were black(the smaller one) and Green. Came with a diagram picture showing which one to use as it showed to different pickuptube ends.
https://www.summitracing.com/parts/mel-m355
Link of oil pump I purchased
Geotrash
Dave
Richmond, VA
Green is the correct o-ring for a Melling pump on your engine.
About the only mechanical thing I can think of that could be causing the behavior you're describing is the pressure relief valve in the oil pan. It's a pop-off valve designed for relieving pressure spikes caused by the action of the AFM system, and could be sticking open momentarily until the pressure drops enough to let it close. Another possibility is the 'dog bone' valve at the rear of the block. Short of that, all other possibilities that come to mind are electrical.
Geotrash
Dave
Richmond, VA
I was under the impression the high volume pump was for the AL block engines and the standard the iron block?
Not questioning your statement that he needs the high volume pump (empirical results sure would support that), just trying to get the data straight in my head. I was also under the impression a high volume pump on an iron block wouldn’t hurt anything.
That's possible, but it's my understanding that all AFM engines use a high volume pump. I could be wrong on that point though.
wsteele
What I had read was the iron block engines (like mine LMG - AFM), took the standard volume pump and the high volume pump was used in the AL blocks. I don't think I am wrong about that, but I also suspect that tidbit probably doesn't have any bearing on what high volume is versus normal volume in the broader LS engine arena. I think in my case, it was what GM said in their TSB regarding oil consumption problems in AFM engined cars.
Looking at Rock Auto, for my engine I think they call out the regular M295 pump as the correct "stock" pump. They do offer a "High Performance" option from Melling in the 10295 which they claim is 10% higher pressure, no mention of higher volume. Having read your AFM delete thread, I know for a fact, if I do a physical delete, I am going high volume, high pressure with what I choose.
I also wonder if the 10295 pump is just a heavier pressure relief spring, or the pump actually has tighter tolerances, etc.
wsteele
Very strange behavior. On my similar engine to yours, stock LMG - AFM just turned off in SW, my oil pressure has always idled slightly above 40 psi when cold, dropping to about 30 psi when hot (temp gauge straight up on the dash). If I rev it cold, it will jump to about 55 psi and stay there with the RPMs. Once fully warmed up, it says just above 40 when RPM's are up.
Geotrash
Dave
Richmond, VA
That's the exact pressure behavior I experience in both of my Denali's now.
Taheezy_88
Taheezy_88
I did reuse the old pressure relief valve. Would this be a good place to start or change the pump first to the M10295?
Electrical I did leave one harness unplugged that plugged to old VLOM that was for the AFM.
Would an oil pressure test be of any worth?
drackill1
