2007 Tahoe Build with Audio
A
Andrew2944r
So got the new tailpipe and Magnaflow installed. Also just finished up replacing the stock Airshocks with some Arnott Air socks for those with air shocks
https://www.arnottindustries.com/
Very easy install and only took me about 2 hours with a floor jack.
Added the Airlift bags for an extra helping hand with the weight.
And now that the airshocks are actually holding air the rear actually came up quite a bit.
Blazed
Accepting Donations
I personally like it better at that height!
A
Andrew2944r
looking good man. If your interested check this out will bring the swaybar parallel again with ground
http://www.tbssowners.com/store/index.php?act=viewProd&productId=201
ALSO MAKE SUREEEE to flip the upper bolts the opposite way. many times the threads come and cut the tire. Flip it the other way so head faces tire
What is the advantages of upgrading and would I even tell the difference as the swaybar is not facing down severely.
Yea I was looking at it but there is no way the thread on mine could cut the tire, has plenty of space.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no prob just making sure on the bolts always safe then sorry.
If you bring the rear to where it was before I would look at getting them seems like rear is much higher now or maybe im seeing it wrong?
A
Andrew2944r
It is higher now. The Tahoe has working rear shocks again, lol
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
whats it at 34 front 35.75 rear?
Capeles
