2007 Yukon 2500 SLT2 purchase
D
Dasanii19
Spicer! Those 2007s have the smaller 5-1350X in the rear, same as the 1500s whereas the 2008 and on use the 5-1410X, same as the 1500 K2s. Front u-joints are 5-795X for all of them.
Thanks man! I was reading that spicer was made by Dana? Will this work? I bought a AAM slip yoke and I figured I’d replace the universal joints as well. Should I replace the front drive shaft ujoints as well? Are these the right universal joints Inneed? Can I buy a quantity of 4 and complete everything?
Yes, Spicer is part of Dana. This is a different u-joint then the one I mentioned to you. Same size but configured differently. Might have grease fittings or be hollow inside which makes them weaker. The ones I posted are solid and sealed like the originals.
The front u-joints are 5-795X and I would only replace them if they needed replacing or while doing needed yokes.
Let me look in my catalog...
Yeah, the -1X are greaseable. Your choice.
D
Dasanii19
Ok, so I buy two of these ? https://www.amazon.com/Spicer-5-1350X-U-Joint-Kit/dp/B00DOIAP1O
Loose_Gasket
