2007 Yukon Denali Intermittent Crank No Start
M
Maxpower_454
What if any type of scanner are you using?
Just a generic little obdii to read codes but I have hptuners. I'll try hooking that up to see if I can find anything else.
I'm going to go over all the grounds on it to make sure theyre good.
M
Maxpower_454
Just remembered that one day while driving it was acting like it had no power. It kept running and driving but I slmost had my foot to the floor just to go up a little hill. It didn't die on me that day but definitely wasn't right.
Could a very dirty fuel filter cause this? I never replaced it. previous owner said it was replaced but looks old / factory.
how many miles are on this thing and what maintenance has been done besides a fuel pump and cam sensor?
I really have no direct clue at the moment but this makes me wonder if it is your torque converter, what does the transmission fluid look like?
clogged cat's can cause no power, so can the tc plus it can make the idle rough and might make starting hard.
not trying to send you down a rabbit hole but could be something to consider if nothing else makes sense.
seems like either one would be more consistent though
rdezs
That sounds like the catalytic converters could be plugged.
I think the 2007 should only have the filter sock in the tank at the pickup. Not really a filter per se. But if you do have the inline filter definitely replace it
M
Maxpower_454
You're correct - no fuel filter. Definitely not a clogged cat. No codes for inefficiency and it has tons of power when driving. It was only that one time it acted up while driving. Didn't act like a clogged cat or obstructed exhaust. almost like a ground or something was weakly holding on
M
Maxpower_454
Whats a TC? I'm thinking about replacing the throttle body but I'd hate to replace yet another part that doesn't need replaced
(TC) torque converter
I wouldn't just replace parts, perhaps more troubleshooting is needed
if you are driving and it is seemingly running fine but has no power under a heavy load then it might be something more physical like clogged cats
mine was clogged and it drove fine if you drove like gramma (to me most people drive like gramma) but as soon as you went to do anything over like 70mph, high rpm heavy load like wide open throttle it had no guts, no power, may as well have been a lawn mower. If I pushed it real hard I would get missfires, yet idling and driving around town seemingly nothing was wrong in any way, you could have driven it like a normal person and never known the difference.
a back pressure test finally revealed the problem, mine should have had like 2.5psi max, mine had 5 at idle and 10 under throttle.
it doesn't explain a no start though.
have you cleaned the throttle body? does the butterfly move smooth? or does it feel sticky and not return quickly to almost closed position?
no answer on miles? previous maintenance?
M
Maxpower_454
No, I never cleaned the throttle body. Has 220k miles on it. Should I clean or replace? Whats the goal with cleaning and could it cause a crank but no start condition?
M
Maxpower_454
transmission torque converter
Definitely not giving me torque converter symptoms.
Is there a diagram showing all the grounds on a 07 yukon denali? I found the one on the firewall. That was broken when I bought it so I replaced it. That was before these crank/no start experiences.
What other grounds should I find and clean?
Thundergunexpress
