Bruce Mace
- Joined
- Mar 12, 2019
- Posts
- 21
- Reaction score
- 4
I have a 2007 Yukon, 6.2 L engine, which after 10 minutes of driving will stall when you stop for a signal light. The time varies as to when this happens but will definitely happen within 20 minutes of driving. The stabilitrak light will also come on. I used to have to wait 10 minutes before it would start again but found by putting the accelerator pedal to the floor it starts after cranking for 10 to 15 seconds. I have so far replaced, Plugs/wires, Variable Valve Timing Solenoid, Camshaft position sensor, Crankshaft position sensor, Throttle body....none have fixed the problem, can anyone offer a solution?
