mikez71
- Joined
- Mar 9, 2023
- Posts
- 1,630
- Reaction score
- 1,911
He said he had no drop to the ground strap (block side), but does on the starter case. ? If I'm reading right..
I already added a new oem ground strap from firewall to the head but didn't make a difference. Added it to a different location and doubled it up with factory old ground as people seem to recommend around here. And there's no direct to block ground that I know of on these.Before adding anything I'd probably first replace the engine-to-body ground with a new cable (rear of left head to the firewall). I'd also remove and clean the battery ground at the block, wherever that is on yours.
I already added a new oem ground strap from firewall to the head but didn't make a difference. Added it to a different location and doubled it up with factory old ground as people seem to recommend around here. And there's no direct to block ground that I know of on these. View attachment 448551
your main battery ground should go here on the passenger side front end of the head, there will be a smaller lead off of the same cable that feeds down to the top of the frame on the passenger side part way up under the radiator support.Or maybe adding a ground strap from firewall to alt/power steering bracket? I know some of em came with that.
voltage drop to the starter "typically" indicates a bad starter cable, just food for thought but if a ground fixes it then great found the problem.
