2008 Tahoe No Start after DOD Delete
JimTahoe
I could use some help. I did a DOD delete with a Texas Speed kit including GM non-DOD cam, LS7 lifters, new push rods, and replaced most of the sensors (cam, crank, O2’s, MAF, etc). After completing the rebuild, the engine won’t fire. It will crank without spark. Fuel pressure is fine and all the rockers are moving. I’m getting a P0016 code, but I would have thought it would have fired and run rough without a relearn on the crank sensor. I also had the ECM flashed to deactivate the DOD. I’m stumped and frustrated after 4 months of working on this truck. Any help would be appreciated.
blackbeard_lives
engine computers are super picky when it comes to crank and cam signals. my buddy had stretched the wire on the crank sensor on his cavalier during an engine swap and it rang good on a meter but needed the wire replaced before the computer was happy enough to fire the spark plugs.
solli5pack
Are you confident that whoever flashed the ECM did it correctly? If you have no spark on any cylinders than thats definitely the place to start. Also any particular reason you changed out all the sensors and did you replace with OEM parts? I'm a big fan of if it ain't broke don't fix it so when I did my delete on my 170,000 mile Burb I kept everything I could.
J
JimTahoe
SOLVED. I did not seat the cam timing gear all the way even though it bolted in fine. I pulled the camshaft position sensor this morning and saw that the gear shaved a millimeter off of the end. I’m going to remove the timing cover and see if I can seat the gear without having to do the bigger job of removing the diff, oil pan, oil pickup tube, oil pump, etc and straining myself to put the diff back. Wish me luck.
Good luck! ;)
Geotrash
Dave
Richmond, VA
Good catch! Yes, you should be able to do what you're attempting without dropping the oil pan at all. That dowel pin is a really common thing to not get seated right.
J
JimTahoe
Final Update - I was able to reset the cam gear without having to drop the oil pan. I got the timing aligned and put in a new cam position sensor. Truck fired right up on the first try and drives great now. I was expecting to need to do a relearn on the cam and crank position sensors, but it seems to run great. Thanks to everyone for the input.
GREMINGTON
2011 Tahoe 5.3 LMG. Did the DOD delete. Will not start now. Scanner tool says cam and crank are not aligned. Gears are dot to dot. Had to tear it down to guarantee this and took a picture this time for proof. Did compression check at suggestion of local pro mechanic. Compression was like 40 lbs or so and did not hold.
I am thinking this cam is not properly indexed to work when lined up dot to dot. Any ideas? I am at my wits end after doing two complete teardowns and reassembly. I did make sure cam gear was seated as previous poster referred to.
I bought the kit from Amazon from Susucar $599.99 in January '25 which may have a lot to do with my problem. Seller was AEPAuto which had 100% satisfaction rating. Same kit is now selling for $342.99 (Feb '25). Seems fishy.
I am thinking this cam is not properly indexed to work when lined up dot to dot. Any ideas? I am at my wits end after doing two complete teardowns and reassemblies. I did make sure cam gear was seated as previous poster referred to.
Probably not at TDC.
Krbobby
