2008 Yukon Denali, 135k miles, part 2!!
T
tgui
I have the 2 main lines in place. A few things will help the install.
- drink and cuss
- tape up the ends of the lines to keep shit out
- make sure the old gasket on the trans isn't still stuck on
- remove passenger side diff bolts and let it hang
- where the one one line meets the trans cooler, I cut out a larger hole for it to fit through. It's got a nasty big 90 degree bend. If not a larger hole you'll need to bend the hard line a bit.
The amount I sawzalled out.
T
tgui
All lines in. Tested. No leaks.
Now to work on the passenger strut to make it new like the drivers.
Then rear air suspension.
Gotta be ready for the winter months.
T
tgui
Passenger side out! Rebuild Thursday.
T
tgui
Not much time tonight.
I was able to get a new exhaust hanger in place. Without one between the ypipe muffler, there is too much sag and flex. Probably not good for the ypipe as well.
Is it ghetto if it works?
Also, I love this damn tool
HiHoeSilver
Away!
Chicago
That Milwaukee is slick. Where'd you get it?
Chadly14
