2008 Yukon Denali, 135k miles, part 2!!
randeez
south florida
did you set up err% with the wideband?
also if you set up the wideband further down stream, just make sure no exhaust leaks before it or it will drive you crazy chasing %s
I use the narrowbands for closed loop VE(and maf) tuning and the wide band for wot (over 100kpa)
using a single narrow band, you may need to discard the STFT/LTFT all together because i think it uses both, if you remove one side its going to run the calc with a 0
T
tgui
I didn't know about the error%. I do however tune the ve using the narrow bands. I removed the downstream sensor, so I should have the STFT and LTFT data right?
Good idea on leaks!
randeez
south florida
yep, if you swapped a downstream you should be good with the st/lt trims
to log the wideband error, you need to log the commanded afr (or lambda) and the wideband
copy and create the VE and MAF tables. so they will have the same axis and column values.
go into maths in the scanner (cntl+m), go to the folder labeled "lambda & afr" you can see there is already a predetermined formula for it, it will show you which values it needs to compute, if they are highlighted RED then you are not logging them.
go to the two tables you created and under "parameter" click and scroll down to "maths" and choose whichever you have all the inputs for
i use lambda because of the flex fuel, it unconfuses a few things, as far as the err% goes as long as all the units are the same it doesnt case
T
tgui
This is an amazing amount of info! Please know I really appreciate the help! I'll for sure spend time digesting this. Wow..
T
tgui
I haven't yet had the time to full understand the above post but the logging works. AFRs seem to be "OK", a little off from commanded. WOT seems to be high 12s.
Here is the log if someone is really bored.
https://drive.google.com/file/d/1pDRVgjf0Wjfb3CK8jjoZo8oLdlV0-Jvo/view?usp=sharing
T
tgui
Thanks for the pointers. I got the maf and ve histograms setup with proper axis scaling from my ROM and %err as the data.
First maf tuning, then all that virtual ve stuff. The wideband makes it easier than using fuel trims.
randeez
south florida
the narrow bands are most accurate in a steady state IE, use them for cruising at a steady 2000, 2200, 2400 etc rpm. i would find some empty roads and just do some real slow acceleration and steady cruising...hold 4th, 5th, and 6th gears to get some out of ordinary data. you can use this type of data to verify the wideband readings at lower rpm
when you're all over the place with throttle input, there is a lot of other tables that get referenced for fueling transient, power enrichment, de-excel fuel cut, etc, etc etc.
T
tgui
Thanks! Working in the MAF now. Lets just say at idle it was trying to ADD 10% and verrrry lean.
ehernande86
