2008 Yukon Electrical Problem
jawilson20
I have a 2008 Yukon that has been having some electrical issues. There are two instances of the related issue.
1) When the truck is running my aftermarket stereo nav system will reboot. As if the power was shortly disconnected.
2) Also while the truck is running, the stereo will reboot AND the rest of the electrical componets will reset (climate controller will set to 74 with AUX and PASS selected, the dash lights will cycle as if the vehicle has just been cranked).
These issues only happen about every couple of weeks, but when they do it seems that it will occur about 3 or 4 times over the course of a day.
Obviously the infrequency of the issue is something that prevents me from taking it to the dealer as I am sure they would want to be able to recreate the problem. I am also afraid that they will immedietley blame my aftermarket stereo/nav system. Has anyone experienced something similar that would suggest that they problem is with the vehicle and not the stereo.
Also, I purchased the truck CPO and the stereo was already installed so I cant say that the problem only started after the addition of the stereo.
Administrator
The only thing I can think of is that there's possibly a short somewhere in the electrical system. Gremlins like that can be very hard to track down... :banghead:
J
jawilson20
What will the dealer do if I take it in and they are unable to recreate the problem?
Administrator
Tell you that there is no issue and possibly charge you a diagnosis fee. Either that or tell you they fixed it by replacing some part, charge you for the part and labor then you'll find out a couple weeks later that it's still happening. I'd wait until it's happening much more frequently unless someone here has experienced the same thing I knows 100% for what it is and what it takes to fix it.
valentinitoronto
