2009 chevy suburban 2500 6.0
RayRay86
Good morning everyone,
I was wondering what performance mods you can do to the 6.0 motor in an 09 chevy suburban z71. Was thinking of roller lifters and roller rockers but don't know how much of a difference that would be and if it's worth it. Will take all suggestions for any performance mods.
Thanks guys
Welcome to the Forum from NH.
Pics of the truck, please.
The performance mods are nearly unlimited for your truck. Can you give us a better/more detailed picture of what you would like to accomplish, as well as your budget?
Motor/Power? Suspension/lift/handling? Interior/exterior lighting? Tires/Wheels?
strutaeng
Dallas, Texas
These engines already have roller lifters.
IDK about roller rockers (unless you are making a lot more power, probably not worth it.)
A more aggressive cam and send it...
R
RayRay86
It would be motor and power. Thanks. I'll post pictures later.
R
RayRay86
What about exhaust systems? I've been told that the engine prefers to work off back pressure and that an exhaust system would hinder it more
strutaeng
Dallas, Texas
Umm, yeah. Long tube headers are always a good thing.
I just run stock exhaust manifolds on my engines (some headers make it challenging to change spark plugs and stuff).
What rear gears do you have? OEM tire size?
Marky Dissod
... been told that the engine prefers to work off back pressure and that an exhaust system would hinder it more ...
back away from the idjit who told you this SLOWLY, lest .
Exhaust systems work off of SCAVENGING, gottdamnt.
... wondering what performance mods you can do to the 6.0L in an 09 suburban z71?
Before you get into modding engine hardware ...
1. What axle(s) ratio do you have?
If you have a 6L80, you want 3.42 (mostly highway) or 3.73 (mostly stop'n'go, some towing),
or 4.10 if you tow very heavy very often.
If you have a 4L60E, you want 3.73 (mostly highway) or 4.10 (mostly stop'n'go, some towing),
or 4.30 if you tow very heavy very often.
Axle gears address how much power is being put to the ground.
Not cheap, but you can't beat the bang for the buck, plus the transmission will last longer.
You will only suffer worse MpG if you drive like a cabbie on meth.
2. don't know where you are, but go find a local tuner who will sit in your vehicle for an hour.
The ecm & tcm tune that will result will make you wonder why GM was holding back so hard.
Costs less than an axle, completely changes the vehicle's personality.
R
RayRay86
Not sure on the rear gears but tire size is 265/70R17 but gonna go down to 255 when they need replaced
Marky Dissod
In your glovebox there's a Service Parts Identification sticker with a bunch of 3 character codes.
GT5 is 4.10
GT4 is 3.73
GU6 is 3.42
GU5 is 3.23
GU4 is 3.08 (barf)
If you have 3.23 or 3.08, do the gears before the tune.
... tire size is 265/70R17, gonna go down to 255 when they need replaced
255/75R17 is 32" tall. 255/70R17 is 31" tall.
My truck came with 265/70R17, but the previous owner sold it to me with 265/65R18.
I very much prefer 255/70R18.
LACajun
