2010 Tahoe Lowered 4/6 Drop
C
coryd
Southwest FL
Any rubbing problems wit the 295/30s ? Up front
There is some occasional rubbing on big bumps but not regularly. Had to do Tony's fender well mod to keep it from rubbing the back of the fender well when making tighter turns.
ddubdb3
i like it! i've been debating on those brake caliper covers for weeks seeing your truck makes me want to pull the trigger. Same boat as you just cant really justify the $4k for a bbk. What suspension setup did you go with up front?
C
coryd
Southwest FL
Thanks man. Yeah, I like the look of the covers, gives a cleaner look behind the big wheels, in my opinion. I know some despise them but to each their own.
I used Tony's (Norcal SS) 4/6 custom kit all around. The front has Belltech drop spindles, Belltech drop struts, and Belltech camber kit. Rear is Belltech shocks, DJM hardware and endlinks, and Tony's custom 6 inch drop springs from DJM. I also installed Spohn adjustable panhard bar and Spohn adjustable upper and lower control arms.
Roman Naputi
New to Chevys, just bought this beast a little over a month ago. After lurking here for awhile, decided it needed a better stance. Lowered 4/6 with NorCal SS custom kit. Also replaced rear control arms with adjustable Spohn uppers and lowers.
Hey bud nice Tahoe Really clean did you have to trim a lot metal to fit those 26's I'm about to order me a set but in chrome for my 08 escapade ext
KBones
No trimming needed for 26's. Just a little heat and pushing the plastic inner fender wells in so they don't rub when you turn sharp
C
coryd
Southwest FL
No trimming in the front, did have to do Tony's (NorcalSS) fenderwell mod though. I did end up trimming some of the rear fender lip though. It was getting a little too close to the tire on big bumps. I think that more due to the rear end not being perfectly centered, which I did adjust the panhard bar after the fact.
KBones
If you don't mind, what are your measurements from the ground to fender lip at all 4 wheels?
ScottieGirl
