2010 Tahoe Replacement Key Reprogramming
ScreamingPeasants
Via the search function, I've found several discussions about key fob replacement / reprogramming but nothing about reprogramming the actual replacement key. I've found several internet sites offering replacement keys and instructions (sent with key) on how to reprogram said key. I am new to GM products; my previous Ford products require two programmed keys to reprogram subsequent keys. Is it possible to reprogram a replacement key with only one programmed key? If so, does anyone know the correct procedure? The owners manual only states that one should see dealer for key replacement concerns. Thanks in advance for any assistance.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
im pretty sure you need a dealer to program the actual key for you.
campkd6
IL
Just had new keys made for my '07 just had to start it with original key then shut it off and start it with anew key within 10 seconds. Hope this works for you
GalaxyBlackEsky
BlackedoutLT3
MD
Speaking of keys. Does anyone know if the key fob from a escalade will work with ours. I like the square style of them
Modded
That Guy
Nope BlackedOut it won't work. I already checked into that. Won't even work on Eskys with the key fob that Tahoe's have (the normal one).
sumo
rhode island
learn something new all the time
S
ScreamingPeasants
Thanks everyone for your assistance. In talking to two vendors I've dealt with in the past, one stated that the "circle plus" keys require two programmed keys to reprogram additional keys; the other said only one was needed and provided the same instructions campkd6 provided ([1] insert programmed key and turn to "run" position for a couple of seconds, [2] turn to "off" position and remove programmed key, [3] insert new key and turn to "run" position for a couple of seconds, [4] turn to "off" position, new key should now be programmed). I am going to try the one key method and will update with results next week. Thanks again.
campkd6
IL
I just did mine two weeks ago because when I bought the Yukon it only came with 1 key and no fobs. Just wished I would have looked on here before I bought the regular fobs I would've got the two way fobs instead. Spent almost 400 on two keys and two remotes and programing.
GM Customer Service
Michigan
I look forward to hearing if this reprogram method works for you. Please keep us updated. Thank you.
Tricia, GM Customer Service.
Paul french
