+1. Also, if you installed the Dorman compressor, it does not switch on for a test cycle every time you turn the ignition on like the original pump does. The only way to test the Dorman pump is to add weight to the backend so that it switches on. It also won’t switch on with the Tech2 scanner like the original will.
I learn something every day.
