2011 yukon xl denali
wsteele
+1. Also, if you installed the Dorman compressor, it does not switch on for a test cycle every time you turn the ignition on like the original pump does. The only way to test the Dorman pump is to add weight to the backend so that it switches on. It also won’t switch on with the Tech2 scanner like the original will.
I learn something every day.
S
southerncwboy34
Still fighting this issue! Have been looking at scanners/ code readers. What scanner do yall reccomend that will let me look at everything and clear whatever codes I need to?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Geotrash
Dave
Richmond, VA
Tech2 is the dealer tool. I love mine and they can be had on eBay for $300 or so.
BigDogYJ
Earth
Tech 2 is the dealer tool. Lots of China knockoffs. Just do the research to find a good reseller.
Otherwise you might have good luck with a Bluetooth reader like BlueDriver. It’s about $100 on Amazon. And while you don’t get full diagnostics you can read codes from different modules in the vehicle.
4plemons
