2012 Yukon Norcal SS 2/3 kit on 22's
KMeloney
Found some of the G5 Escalade tail lights on EBAY. Any other recommendations on where to get them? Are they plug & play, or do I need a special harness?
If you get the aftermarket lights, they're plug-and-play. If you go with the actual Esky lights, you'll need a modified Esky harness.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
what does it measure all the way around from ground to fenderlip?
34.25 front and 35.5 rear?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Thats pretty good. Im looking to get 33" front and 34-35" in rear using belltech spindles and adjustable struts.
Depends on what springs were used from gm in front. There can be up to 1 inch variance on them. My esclade was 36.75 and 38.5 stock on 285 45 22. Now im at 33 and 33.25 on 295 30 26
guy from norcal
mine now measure 36" front and 38 1/4 rear. I am not sure if the belltech struts are a true 1- 2 " drop with spindles or not ?
Levi0320
