Yea! EZ fix.
@jt8412 If the weird electrical problems come back be sure to start with new battery cables for both -/+ leads. For now, after a drive verify that they are not hot to the touch or melty looking from being loose in the past.
RockAuto is a sure fire place to determine and order the battery cables.
If you need a DTC / code reader that’s built in and a way to unlock features in the truck that the 2022 truck have, BT Dieselworks Autosync will integrate, add and unlock them so you can read & clear codes through the dash display and view back up camera 24/7, even going forward… Too much other stuff to list. 20% off now too. They Never go on sale!
BT DieselWorks
www.btdieselworks.com
The other feature that unlocks the drivers Navi screen in motion to use the onscreen BT phone keypad, input navigation info, movie selection and viewing while in motion may be on sale too.
Navigation radio module programming for 2012-2014 GMT-900 trucks/SUVs. Exclusively available from CCE, this programming will allow you to customize parameters in your vehicle’s navigation radio. The only model nav radio that is currently supported is the "UYS" nav radio (check your glovebox...
www.customcalibrationengineering.com
Here the module to add A2DP Bluetooth (music & audio) from phones to your Denali Bose system. Essentially it means kids watch a movie with headphones, Mom & Dad listen to music off Spotify or Pandora and simultaneously run Waze or Google maps Audio through your Bose sync’d to the trucks existing navigation screen.
Crux BTS-GM1X Bluetooth Music Streaming for Select GM Vehicles (with Factory XM Tuner) 2012-2014
The above SW updates are for the 12-14 Trucks only with the HDD Navi system like yours.
