2015 HMI Unlock - Video in Motion
PB&J
tenbigblinds - was there ever any resolution with the green line at the bottom of the screen? Is this and iphone6 issue or does in happen on the 5 as well?
WBHMSU
Seagal Enthusiast
Cool. This is basically the same solution we're talking about in the other thread here (see the last few pages):
http://www.tahoeyukonforum.com/forum/showthread.php?t=63504
Similar converter, RCA to HDMI. Just make sure that you buy the right cable for your phone - HDMI on end of the cable and whatever connector your phone takes on the other.
T
tenbigblinds
The company I purchased through has not sent a replacement converter yet. Green line still there
2015i Yukon SLT 5.3L
- Open Road (Nav & Rear Entertainment), Marimoto HID Upgrade, 24" Lexani Luxury Wheels, Pirelli Scorpion 305/35/24, WeatherTech Digital Fit, HMI (Video in Motion & Cell Mirroring) Upgrade, vLED Fogs/Plate/Backups/AirRaid Jr.... Looking to do more!
jl449
Salinas, Ca.
That suck ... you would expect faster service not unless it is back ordered from their supplier. either way they should compensate you.
Question... I ordered a a face plate with HDMI and USB similar to yours. I removed the back cover. Where you mount your face plate (between the 4 torx screws) there is no room. Did you dremel the back to make room ? My face plate from the back sticks out little less than an inch.
PB&J
So I swapped the white plastic HDMI - RCA converter for the one photios recommended - the metal black one. Green line is gone and picture seems to be a bit more clear.
Now if I can get sling box to stopped shrinking into the corner when I press zoom, I'll be all set!
T
tenbigblinds
Where did you get the converter?
And to the other post... Yes I had to dremel the back.
Dallaslady
