So my unlocked module arrived, I read and reread the posts about installing it and the directions that came in the box. Once you figure out how the connectors come out (tab on top) it was a quick install and worked perfectly. Nice bit of kit.
Received the new converter. It works perfectly without the green bar across the bottom. I absolutely couldn't function without the unlock. I have about 700 movies loaded on a 4TB hard drive and they constantly play on the screen each time I drive. I do use the NAV and simply display that on the small dash screen... Love my ride!
Have you found a way to disable the prompts when using the nav? I love the fact that the nav can be used on the small info display above the steering wheel, but... if something is being played on the main front screen, a prompt is displayed, covering up whatever is playing, requiring an input to resume. I'd love to turn those prompts off.
