2015 Tahoe..Misfire
OR VietVet
Multnomah Falls
Military
Willamette Valley
Ok. When they did the push rod and rocker did the plugs get changed at the same time? If not I would expect that the plug could have been partially fouled and may need changed now plus, most people change the plugs at 100k miles anyway, so change them all. Plus, as far as you know, the misfire is on another cylinder. Plus, when they diagnosed the previous misfire they may have swapped some plug wires to see if the misfire would follow a bad wire and the wire could have been damaged. Do you have any DTC's? Does this current misfire feel like the saame misfire as before, meaning it feels like just one cylinder?
BigWolf504
BigWolf504
Gulfport
It still is I was wondering if anyone else was having this problem
Sent from my SM-N960U using Tapatalk
plenty of people have had a misfire on cyl 7, for a variety of reasons, there is no common denominator here.
could be bad spark plug, spark plug wire, coil pack, coil pack wire harness, fuel injector, fuel injector wire harness, internal engine damage, could even be the ecm or ecm wire harness and maybe a couple other things I am missing. you will need to see a mechanic.
89Suburban
Bull in the china shop
SE PA
CHECK THE SPARK PLUG.
And be careful doing so because it is hard to get to and easy to cross thread trying to put back in.
daddy g
