2015 Tahoe - Starter issue
wjburken
Eastern Iowa
We are having an issue with the starter on our 2015 Tahoe (111,000 miles) where you'll turn the ignition key and nothing...... try it again and it starts right up like nothing is wrong. It's happened several times in the last week and I'm concerned that the starter is beginning to fail. I've read some other posts about similar issues with older Yukons and the recommendation was to check the wiring and voltage and possibly replace the starter.
Thanks.
Paul
Any update on your situation? If you’ve solved it, please share what you ended up doing.
BlaineBug
Clown World
While you're in there, I would check the ground to frame behind the passenger side wheel liner. It's fairly low and easily accessible, the liner does not need to be removed.
daddy g
