2015 Tahoe with Fox 2.0 Coilovers + 275/60/20 K02s
DWSmoot
Charleston, SC
Also, you'll need to get an alignment after install, my camber was way off (assuming you decided to lift the front). They compliment the factory rear air shocks well, I replaced mine with new factory versions and they seem to ride decent.
So did you end up adding a rear spacer?
15TahoeLT
15TahoeLT
I didn't- after about a month of driving it the front settled in a little bit and after measuring, the rear is only about 1/4" lower now maybe less. You can't even tell with the naked eye- looks perfectly level. Just went through the front end and to make sure everything was tight last week and it looks good. IMG_3373.jpg IMG_3376.jpg IMG_3375.jpg
ScottieGirl
