2015 Yukon SLT Towing
powderbrake
St. Louis, MO
I have a 2015 Tahoe with the Max trailer package, and I occasionally tow a 7 X 16 dual axle trailer, which weighs about 2100 pounds, with about 3000 additional pounds of load.
The 2015 tows it very easily, and performs much better than my 2007 Tahoe did without the higher ratio axle. I do use a weight distribution hitch.
When I ordered the new Tahoe, I was worried about gas mileage with the higher ratio axle when I'm not towing. It turns out the 2015 gets 19+ MPG on the highway at 70-75 mph. That is so much better than the 2007, I'm very happy with it.
HAARubicon
Nice write up on towing experiences.
For the OP, don't skimp on the hitch for a Travel Trailer. I am pulling 35 footer (12000 lbs) with my D-Max powered 2005 3/4 ton Suburban and use the Hensley Arrow Hitch (Pro Pride is its equal or some say better). They make a light duty for lighter trailers, but believe me when I say it makes all the difference in the world on the way the Tow vehicle and trailer feel when hitched up. They are expensive compared to a standard Weight Distribution hitch, but so is your tow vehicle and the trailer your pulling.
These hitches take out the sway, they do what they claim. My hitch has 80k miles on it and still works like new.
sysmast
Here is my report, first, my Tahoe has the max towing package (3.42 gears, integrated trailer brake, rear air suspension, it is also a 4x4, rated at 8200lbs for towing. I have a 28 foot travel trailer that is 5700lbs dry. Since I am dry camping for 5 days, I need the water and propane topped off. I figured with wife and three kids worth of "stuff" we add about 1200lbs including water, propane and gear. That brings my trailer to 6900lbs, well within limits.
Setting up the hitch (tahoe has 20" wheels): I had to adjust the hitch to a lower setting (previous setting was for a 99 Suburban). The tahoe is 3 inches "taller" at the hitch than the OBS suburban. I was contemplating the weight distribution bars, do I need them or not, I figured with the air suspension I probably didn't, but in the back of my mind, why put the extra strain on my tahoe, so I did add the bars, I also installed the sway bar (remember you MUST have a sway bar in CA if the trailer weighs more than 3000lb pounds), and finally hooked up the electrical.
I then went to the local school parking lot to setup the brake controller, very easy to use.
Then off we went (forgot to mention Tahoe was topped off with premium gas, I always use premium for towing, 26 gallons). Acceleration was great merging onto the freeway (tow/haul mode is on). First grade was the Cajon Pass, not a very difficult grade 3-4% if that, 7MPG, I was in the lane next to the truckers lane, average 52-57MPH, not bad. Got onto the 395 north, 17 miles of 50MPH max for road construction (what a pain). After that 55-65MPH, 13-15MPG. Arrived in Bishop, topped of gas, had lunch, back on the road.
Second grade (IDK the name) is a few miles north of Bishop, much shorter than Cajon, but much steeper, 4-5%, averaged 4MPG, but only took 15 minutes.
Now in the high country, with the third and final grade, again steep and short, I would guess same percent as second grade, 4MPG also.
We arrived at our campsite at 4pm in the afternoon, leaving at 7am in the morning. Not 1 issue with the Tahoe, trans temp did not get hotter than 205, engine oil temp did not seem to rise much. I set the cruise to 60 MPH, 80% of the time, with tow/haul on the duration of the drive. Granted we did drive through the desert in the morning, I would guess 3-5 degrees hotter for the fluids if driving during peak temps.
Disclaimer, we drove from elevation of 1200 feet, to June Lake at 6700, not a whole lot of braking, but when I needed to brake you really couldn't tell the trailer way their. It took my wife and I about 15 minutes to setup the brake controller, read the manual!
Interesting items I noticed, only 1 time did the electric fans got to "max" speed, pulling out of Bishop (98 degrees) to start the 2nd grade, they stayed on the whole grade, as soon as we "leveled" off, they decreased speed. Going from a 4 speed with 3.73 (OBS Suburban) to a 6 speed with 3.42, I felt the Tahoe "pulled" better, the horsepower is probably a significant factor, 100 more HP than the vortec 350.
Just my $.02 on towing with the 15's.
Malones, thanks for the nice write up! This is very nice for those concerned with grades.
Do you have any thoughts on handling at highway speeds? How much of an impact does that type of trailer have with cross winds? I see you had a suburban before, any comparison to that or 1500/2500 pickups?
Asking since I use the same truck(w/ max trailer pkg) and want to upgrade the trailer to one similar to yours. The smaller trailers I've tow'd so far (<3,000 lbs) are not even noticeable behind this truck!
My worry is mainly due to the short wheel base of the tahoe, with a long ~30ft trailer.
The V8 has plenty of power, as you don't seem to have much trouble with steep grades. Also, the truck weighs more than enough, so the trailer shouldn't pull the truck around too much because of weight.
Thanks again!
Yukon John
SE florida
Thanks for the great write up. I am still breaking my 2016 Yukon in (Max Tow SLE)...less than 1000 miles.
I will be towing a 26' boat on a twin torsion axle trailer with 4 wheel disc surge brakes. I figure I'm towing about 7500# gross so I have 1000# safety factor. Tongue weight is about 600# My previous tow vehicle was a 2005 Escalade ESV with AWD and 6.0 Vortec HD and did a great job.
My concerns now are how 2 WD/Posi will perform at the ramp as well as on wet pavement towing.
Depending on how the Yukon performs I may upgrade the brakes to electric over hydraulic to take advantage of the integrated controller.
Stay tuned.
Yukon John
SE florida
OK...at 1000 miles I towed my 26' Thunderbird Formula boat for the first time.
I am in summary very impressed with the way the Yukon handles the 7500# gross weight of the boat and trailer. Acceleration is a bit better than my Escalade 6.0 LQ-9 was...probably due to the 6 speed automatic and a little more torque. The braking with the trailer surge brakes was good. My big relief was how well the Yukon pulls the boat out of the water on a steep, wet ramp at low tide! The 3:42 Posi 2 wheel drive does a great job.
At 65 - 70 MPH the rig is very stable but I have to say the ride is not quite on par with the Escalade ESV...strictly a wheel base issue. I do however enjoy how much easier it is to maneuver this rig in traffic with the standard wheel base.
The Auto Leveling is flawless....with the Yukon running I lowered the 600# tongue onto the 2 5/16 ball...the compressor kicked in and automatically leveled the load. This is my first experience with a Factory Back Up Camera...HOLY CRAP...lining the ball up with the tongue is sooo much better !!
If there is a down side it's the mirrors....they SUCK !!! Someone needs to come up with some decent tow mirrors for these vehicles...what they give us from the factory is a joke !! My total towing length on the trailer is about 32' and it is down right scary trying to see down both sides of the boat !!
I am looking for a correction for this ASAP...suggestions are welcome.
gGM Fan
So Calif
I tow a Airstream travel trailer with our Tahoe and I use Melinco mirrors. I'm satisfied with them.
why_fly_high
I have a 2015 Tahoe 4WD with max trailering package. I am looking at a toy hauler that is 5500lbs. I could see it fully loaded hitting 7500 tops. We live in Oklahoma so not many hills and would probably not go more than about 300-400 miles from home tops. The trailer is not as long as others here at only about 25ft long but seems tall. I am afraid I am going to spend this chunk of money on a trailer and then hate life while pulling it. I would be within published manufacturers limits but am still worried. Anyone else towing near capacity of there Tahoe/Yukon?
Thanks!
Wattage2004
