2016 Yukon Denali. Vehicle got stuck in the snow. A ball was used in the hitch to pull it out. Next day the battery was dead. After jumping, it had the Service Trailer Brake System message. Didnt think anything of it except now the battery won't hold a charge. It will jump and run fine but left overnight the battery drains. The vehicle ran fine prior to using the hitch to pull it out of the snow. Could the brake system be causing the parasitic drain? Is there a fuse or relay i can pull to reset the trailer brake system? I've read there is also a module in the rear that could be the cause of the Service Trailer Brake System message but nothing I've read mentions the parasitic drain. Thanks for any assistance!
