2016 Denali fog light leds?
Carpenter2361
I didn't have to remove the whole inner fender just remove bottom bolts and a couple along the edge. It's a little aggravating but way better than taking whole bumper off or removing whole liner.
And you left the wheels on?
Carpenter2361
How did you adjust them after you installed them?
jdeastbay
Exactly. I just finished a few minutes ago. Need to remove the lower two bolts at the bottom of the inner fender. Then climb under and there are two bolts plus a plug attaching the fender at the bottom. Once they are all removed from below or side of vehicle you'll have simple access to remove from housing (1/4 twist to left) and remove OEM bulb (push release, at base toward wires with grip lines embedded on it).
SSVTahoe16
