2016 Suburban LT Fog Lamps install with OEM switch
bezimmer
Northern VA
And finally (for now), here's the underside of the fuse block top (fuses and relays are found on the other side of this half of the fuse block) showing where X1-J3 resides. Connectors with terminated leads form the bottom of the fuse block and are what this plugs into. The significance of this is that I believe that if there were different fuse blocks for vehicles without fog lamps, this J3 pin wouldn't be there. Nor would the fuse. That also might mean while the fuse blocks are all identical, it's just the wiring harnesses that aren't. Makes sense, to me anyway.
russjameson
Need help.
Hey there, I have had this page saved for quite sometime to do this on my wife's Suburban. I am pretty mechanically and electronically inclined.....untill 2015 I guess.
Here are the problems I have had so far.
I didn't have a wire for pin 6 on my switch harness. I had one in 10 (rear fogs) but it didn't work. I pulled it out of the connector and put it in 6. It works fine giving the signal to 611T.
My problem lies with the blue wire in X5 pin 22.
When I attach the yellow and black wires to it I have a constant ground to the Brown output wire of the 611T. Even when the lights are off and on Auto. When the switch is in parking lights and on headlights the switch works fine.
But when I turn the car off the fog lights don't ever go off.
For some reason the blue wire isn't switching off. When I ground the yellow and black wire the lights go on and off just fine. Im just looking for control from the parking lights.
I have looked at the diagrams online and have no clue where to tap so the parkinglights control the 611T.
Thanks in advance for your help.
russjameson
Anybody?
I'd like to get them working before she goes for her state inspection.
Thanks
Chuck13
Hey all,
I wasn't able to find many (or any) cases where aftermarket fog lamps were added to a 2015+ Suburban /Tahoe (or similar generation) with the OEM switch, so I created an account here to share for anyone else that's interested.
Let's get to it…
Tools you'll need:
7mm socket driver
10mm socket driver
T15 torx driver
Suggested tools:
Clip removal tool
Electrical tape
Wire ties
Parts used:
Spyder FL-CTAH15-C fog lamp kit
GM headlamp switch w/fog part# 22752195
DEI 611T
Preface
I was hoping to use as much factory wiring for this installation as possible to keep everything as “factory” as possible, but mostly to avoid doing more work than I had to :). I dug into some schematics to see what the factory wiring was like and then proceeded to look for all the wires in the truck before getting dirty.
The good news – the factory fog lamp fuse was installed in the fusebox from the factory, woohoo. Also, the wire from the headlamp switch harness to the BCM was present at the headlight switch and at the BCM. The wire from the BCM to the underhood fuse box for the OE fog lamp relay trigger was also present at both the BCM and the underhood fuse box, excellent!
The bad news – the wires that are supposed to go from the fusebox to the factory fog lamps weren't in the wire bundle going to the front grille where they're supposed to be. I investigated further and found that the wire isn't even pinned in at the fusebox, way to cheap out GM!
Here's where the wire should go, notice how pins are populated to the left and right of the pin we need, but not where we want one :(
This setback meant that I would have to run my own wiring from the aftermarket fog lamps to the battery, and a relay to to control it all. I'll still be using the factory trigger wire for the factory fog lamp relay and just use that to trigger my relay.
Reverse engineering
The factory front fog lamp circuit works as follows – when you press and release the fog lamp request button at the headlamp switch, this sends a ground pulse to the BCM. The BCM interprets this pulse as a request to turn the fog lamps on, and if the headlamps are on, it sends a ground signal to the underhood fusebox to the fog lamp relay. When the fog lamp relay clicks on, it sends power to the front fog lamps and there ya have it.
Since I don't have access to a programming tool to enable the fog lamps feature on the BCM, it didn't do anything when I installed the new switch, as expected. No matter, I brought the 611T into the picture to replace the BCM's role in this party. So the 611T will take the momentary pulse from the fog lamp switch and control a latching on/off ground output that I will feed into the factory fog lamp relay wiring. Since the factory fog lamp relay wiring is missing at the fusebox and I'll be using my own relay, I'm pretty much just hijacking this wire as a way to get through the firewall without running any new wiring.
611T wiring
Black – to BCM brown connector, Blue - pin 22
Green – to headlamp switch, Blue/Gray – pin 6
Red – to BCM brown connector, Red/White – pin 4
Yellow – to BCM brown connector, Blue – pin 22
Brown – to BCM brown connector, Brown – pin 10
611T wiring explained
The module is “active” when the Black wire is at ground and the Red wire is at 12V+. I wired it up so that it only has ground when the parking lamps are active so that the fog lamps can only come on when the parking lamps are on, and turn off when the parking lamps turn off. The Green wire receives the momentary pulse from the headlamp switch to control the MOSFET that the Yellow and Brown wires go to. The Yellow wire is looped over to the Black wire so that it only has a ground input when the parking lamps are on as well. Lastly the Brown wire is what will trigger the aftermarket fog lamp relay on/off witch each press of the fog lamp switch when the parking lamps are on.
Interior Disassembly
Remove the fuse panel lid on the left side of the dashboard – it's the large plastic panel covering the interior fuses on the left dash.
With that door off, remove two T15 torx screws from the side of the lower dash panel as shown.
Next, remove another two T15 torx screws holding the lower dash panel from underneath, they should be easily visible.
Optional – use a small flathead screwdriver to unclip the hood release latch and separate it from the panel. You don't have to do this, but doing so will let you completely set that panel aside once you unclip it from the rest of the dash assembly.
You should now be able to unclip the lower dash panel. There are about 3-4 clips holding it on now, just get a good grip and pull towards the rear of the truck. These clips can be stubburn.
Once you take off that lower dash panel, you should now see two 7mm bolts holding the switch panel in place. Take those bolts off and pull that panel off – again, pull toward the rear. There are maybe two or so clips on this one. Unplug the harnesses and swap out your switch then set the whole thing aside.
The switch is held on with these clips...
Exterior Disassembly
Start the engine and turn the wheels all the way to one side.
Remove the 7mm bolts securing the felt wheel-well cover on the front bumper.
Get under the bumper and remove two 10mm bolts and a clip holding the felt cover on from each side of the truck.
Reach in and remove four 10mm bolts holding on the fog lamp blanks. (the left-most screw is out of view in the image below due to the angle)
Put the new fog lamps on, turn your wiring up through the fender and into the hood area, and put it all back together if you'd like. Don't forget to secure the wiring with a few wire ties to keep everything tidy.
Wiring
Headlamp switch
Fog lamp request wire (Blue/Gray)
BCM
X5 connector with parking lamp (Blue) and fog lamp (Brown) relay activation wires and a decent constant 12V+ source (Red/White) for the 611T note: the fog lamp relay wire may be Brown or Brown/White, take note of which color it is for you!
Underhood
Trigger wire for your fog lamp relay, should be the same color as you found inside at the BCM
Just in case it's not exactly clear from the previous picture where that harness is, here's a more zoomed out shot...
Good 12V+ source for your fog lamp relay
Appendix
For your reference, here's a rough block schematic of some of the circuits discussed here.
And lastly the final product
All lamps on
Parking lamps and fog lamps only
Fog lamps off
Do you still remember the setting on your 611T? Thanks!
russjameson
Does anyone check this anymore?
What if I used the 611T to give me a negative for the fogs, using a constant ground as a input for the 611T when the Foglight switch is on, and I tap into the positive lead going to the parkinglights and use that as the positive for the fogs. That way the fogs can only come on when the parkinglights are on
Rdr854
Northern VA
Need help.
We have rear fog lamp capabilities? How so?
Jessie Sanchez
Hey all,
Let's get to it…
Tools you'll need:
7mm socket driver
10mm socket driver
T15 torx driver
Suggested tools:
Clip removal tool
Electrical tape
Wire ties
Parts used:
DEI 611T
Preface
Reverse engineering
611T wiring
Wiring
Headlamp switch
BCM
Underhood
Appendix
All lamps on
Fog lamps off
Jessie Sanchez
Help needed! I wired up all as I read but fog lights turn on and stay on even when vehicle is off. I have 3 wires from relay that came with fog lights...white I ran to trigger brown wire underhood...red was connected to red wire run in harness with brown trigger wire...black to chassis ground...as soon as I grounded black wire, lights immediately turned on and would not go off until ground was disconnected.
htowntahoe
