jeffk19426
- Joined
- Mar 11, 2017
- Posts
- 2
- Reaction score
- 0
Question. When I opened my fuse box under the hood, I actually have a fuse in
Did you every get an answer to your question about no wire in pin six? I have a 2015 Tahoe LT and am missing the same wire as well. Does this mean the new switch with the fog light button will not work? And that I will need to use a separate switch and run a wire through the firewall?
Here is a pic of the wires on the back of the switch.
Thanks,
Hey guys,
I am having a bigger problem, my 2016 Suburban is not even wired at the switch, pin six blue-gray wire is missing, out of twelve pins at the connector there are only 9 wires coming in. I do have a blue-grey wire going in the switch at pin 10. Can somebody chime in and tell me how to go about this? Or should I just use the switch that came with the harness and run wires through the fire wall?
Thanks,
Thanks,
