NickTransmissions
Sin City
Sounds about right. Those transmissions are expensive relative to the previous generation of four-speeds (especially compared to a similarly built 4L60E) due to higher cost of parts plus all the parts that have to be installed for a proper overhaul. Feel free to shop around but my guess is that all the quotes you'll gather will be within a couple hundred of each other and may vary a bit in terms of what exactly is done with the transmission.So the shop just called. I won’t have time to get over there until tomorrow for them to explain everything to me. But they are saying the torque converter is the issue, but that the entire transmission needs to be rebuilt. $5,800 or $6,025 with heavy duty TC. Ouch. Should I get another opinion? This is a reputable transmission specialist that’s been around a long time and has done work for me before. Huge expense!
Find out if their HD torque converter comes with a billet cover and .050+ converter clutch (or perhaps multi-disc set up) and go with that if so.
- Are they replacing the TEHCM with a new one directly from GM?
- What updates/upgrades will be installed (if any)?
- What is the warranty?
