2016 Yukon Transmission Shudder
The transmission bench
So the shop just called. I won’t have time to get over there until tomorrow for them to explain everything to me. But they are saying the torque converter is the issue, but that the entire transmission needs to be rebuilt. $5,800 or $6,025 with heavy duty TC. Ouch. Should I get another opinion? This is a reputable transmission specialist that’s been around a long time and has done work for me before. Huge expense!
Sounds about right. Those transmissions are expensive relative to the previous generation of four-speeds (especially compared to a similarly built 4L60E) due to higher cost of parts plus all the parts that have to be installed for a proper overhaul. Feel free to shop around but my guess is that all the quotes you'll gather will be within a couple hundred of each other and may vary a bit in terms of what exactly is done with the transmission.
Find out if their HD torque converter comes with a billet cover and .050+ converter clutch (or perhaps multi-disc set up) and go with that if so.
- Are they replacing the TEHCM with a new one directly from GM?
- What updates/upgrades will be installed (if any)?
- What is the warranty?
B
Borrowed_Time068
I’ll find all that out tomorrow, thank you. Just wondering at this point if going with a new or reman trans would be a better option. Guess that will largely depend on what the shop will offer for a warranty. Thanks again!
You're welcome, Borrowed_Time...If the builder is competent and knowledgable, you'll get a much better transmission from him than from any reman company, including GM...That said, GM provides 100k/36 months while most rebuilders/independent shops including me give one (1) year, unlimited mile warranties (I sometimes warranty beyond that if I feel it's called for or customer is a really good customer where the failure is minor or not entirely the customer's fault).
B
Borrowed_Time068
Just a quick update.. truck is currently in the shop getting a complete rebuild with an HD TC. The owner also recommended I get an AFM disabler to stop it from switching to 4 cylinder mode. He said this system is problematic with these engines and transmissions. Looking at the one from Range Technologies.
Djgz71
I had the transmission replaced at 77k miles, 2k outside of my extended warranty, grrr. It was about 4,400 for a rebuilt transmission. Coleman Taylor was the shop and they do about 6-8 GMs a week. They keep your old one and have a part of the shop that is constantly rebuilding. I have no idea what parts or upgrades they put in over OEM but they said many parts were better than OEM. No issues in the last 2 years. With inflation I am guessing it would now be over 5k for the same job
B
Borrowed_Time068
Mine had 103k. No towing and 80% highway miles. Sad we have to go through this. My rebuild is costing $6k with several upgrades and 18 month, 18k mile warranty. Pretty big unexpected expense.
Djgz71
same type of driving for my miles. This included a 3 year 36k warranty as well.
Pericles
I have a 2016 escalde with 170k miles now and the trans is going out. I've also had a few quotes in the DFW area. If anyone can help me ask the right questions as far as torque converter etc bc when i got these quotes I had no idea what to ask. Here were the quotes.
Rebuilt with all new GM parts was 3500 with a lifetime warranty at eagle transmission.
Remanufactured directly from gm and installed for 5500 at high tech transmission in Arlington. I don't know what to do, but the clunking and slipping in first gear is getting scary. I just don't want to be stranded in 109 degree heat.
Torque converter: make sure it has a converter clutch that's at least .050" thick. Factory POS clutch is .020-.025".
Your symptoms are likely being caused by a cracked 1-2-3-4 piston in the 3-5-R drum. You'll eventually lose all forward movement.
Id find out how that one shop is defining "lifetime".
See my 6L80 Info thread for all other parts-related questions and what specifically needs to be installed at minimum and post there if you have any addl questions.
matty40
