2018 Tahoe premier flowmaster 40 exhaust
Ghost10
Ghost10
There are a handful of favorites that produce a great sound and no drone. I can only speak for what I have experience with. Also, I tend to be cheap since the name branded onto the muffler or how much money was spent on it doesn't mean shít to the engine farts blowing through it. The tried-and-true crowd favorites are the Magnaflow #12589 (22") or the "one notch higher" #12259 (18"). Magnaflows are nice, but pricey, so I opted for the clone made by AP Exhaust, from their Xlerator line. When my exhaust was otherwise stock (manifolds, cats, etc.), I had the AP XS1259, AP's clone of the Magnaflow #12259. IMO, it was absolutely perfect. It only came alive when on the throttle, and I'd lower the right rear window when next to a wall just to hear it. When cruising, you'd hear a distant V8 hum if you were listening for it. NO drone at all. It was about $33 on Amazon back when I bought it, and is currently $62. Their clone of the Magnaflow #12589, which is the same muffler just with a 4" longer body, is $63 on Amazon (XS2589). You could call this a "stock+" muffler since it's almost as quiet as stock, just with a hair more attitude at idle and when cruising, but would have a decent bark with hard throttle. There are similar ones, if not the exact same muffler in a different box, branded as Jones MAX Flow. Their part numbers are basically the same as AP's, such as the 22" Jones MF2589 ($84 at Summit) and the 18" MF1259 ($51 at Summit). Having a Flowmaster 40, I think you'd prefer the one-step-louder 18". The Jones MF1259 is the cheapest of the bunch, but look at shipping, etc. and compare to Amazon.
This is very over whelming for me lol!
So pretty much the series 40 is not good for my truck and the only way to get that v8 Chevy sound I want is to swap it out? Curious if I run it for 30 days the sound might mellow out some or do I need to just realised that the series 40 was a bad idea and I ******* my self ?
Don't overcomplicate it!
The 40 series is just a loud style of muffler- on your Tahoe, on a '93 Silverado... anything with a small or large engine. It's a chambered/baffled muffler so it just bounces sound waves around rather than muffling them. The sound waves bouncing around do collide with others, so there's some small amount of muffling from the cancellation. But it's just cancelling whatever frequency of waves that are colliding. Which, obviously, are not the low frequency notes that carry longer distances and resonate throughout the cabin. There's nothing inside to "break in", so the sound won't change over time unless a baffle actually breaks (failed weld). Then, it'd likely be a little louder and with a rattle.
All you gotta do is cut out the Flowmaster and replace it with another muffler that will do what you want. It's not rocket surgery. Did you weld in the Flowmaster or had a shop do it? You said you spent $260, so I hope that was on parts and labor and not just on the muffler! Regardless, I'm sure the Flowmaster has 3" inlet and outlets. It's also shorter than the stock muffler, so there would be a length of pipe welded in to make up the difference. Cut out the Flowmaster and however much of the make-up pipe necessary to splice in the new muffler, then connect it with the necessary couplers and cinch it down with clamps. It'd take probably an hour, tops, with a good hack saw blade and a ratchet to tighten the clamps. You could sell the Flowmaster to recoup the cost or most of the cost of the new muffler.
Ghost10
Ghost10
I had a shop do it thebdudde is a old guy he refused to straight pipe it like I originally wanted lol glad I didn't though because I'm in Cali and I'm sure it's illegal and would just be super loud. I'll just go back to the guy next week and hopefully he's cool with helping me figure it out without dropping another couple hundred
Just get this: https://www.summitracing.com/parts/jex-mf1259 or this: https://www.amazon.com/AP-Exhaust-Products-XS1259-Muffler/dp/B004A5QJN8 ($7 cheaper and might arrive sooner). Bring it to him and just say "please help me" in your best pathetic voice.
Sound clips?
Do you recommend I remove the resonator ?
I have some of when it was stock with no resonator, when I first installed the XS1259 (same as Jones MF1259), then exactly a year later (plus about 23 minutes ;) ). Lemme find some links...
Stock, no resonator:
With AP XS1259:
AP XS1259 after "broken in":
It has to be the way the camera picked up the sound, but the "stock" video sounds louder. This is not the case.
As for losing the resonator, I couldn't tell any difference when driving. I MIGHT have heard a slightly healthier grumble when idling if I really listened for it, but that could've just been in my head. Besides, it's for killing an exhaust note when in V-4 mode, and it only idles in V-8 mode. Really, I removed the resonator for aesthetics. It's very visible from behind and I wanted a cleaner-looking, snazzier tip. That little project is outlined in the first page of my build thread: https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/post-1115977
Yes, mine's a GMT900, but the engine size, firing order, etc. is the same and the exhaust stuff is all similar enough to be comparable to your generation.
Ghost10
Ghost10
With AP XS1259:
Thanks for posting those videos.
Found the XS1259 For $58
Just curious why are most of you guys never recommending flowmaster, is it just over priced branding ?
STORMIN08
You need to put the resonator/flapper back on to get rid of the drone from the cylnder change. Alternatively you can try the Range device which keeps it in V8 mode. But you lose mpg....
the lose of MPG is a completely false statement...mine lost no MPG, and since going with a tuner...even lifted with larger tires, it is maintaining the same mileage
the type of muffler, Flowmaster particularly has a noticeable drone on most SUV's...even our older 99 with a 7.4, drones. that truck has been the test bed for several exhaust cat backs...i have not changed on exhaust on an SUV since. my 2011 tahoe received the SLP resonator delete, and that was the best sounding one to date.
Ghost10
Ghost10
BTW I just learned yesterday that tow haul mode is amazing when not towing anything.
HamptonGarage
