2019 Tahoe 5.3 LT Battery Drain
2019Tahoe
2019Tahoe
Cold air puts moisture in weird places. Winters seem to enjoy the havoc.
Although the battery cables are known to corrode from the inside out, this problem sounds more like frost forming underneath the engine fuse block and creating the new connection.
Remove the fuse block and check underneath. Consider replacing the battery cable, if you haven’t already.
Are you taking about the fuse block located on the battery or the actual box that has all the fuses located on the drivers side?
rdefeo
Same thing is happening to me (2018 Tahoe Premier). While at home, I noticed that my phone would gain/lose a connection periodically. But it happened so quick I didn't know what it was - the car "waking up" could be the culprit. Temps have been below 30F and my battery died. It died again after a recharge and I figured it was time to replace it since it's been 6+ years. New battery died after the first day, but it's possible that it wasn't fully charged to begin with? (Although that seems unlikely). I have not changed the location of the key fob when it's been inside, but will try to keep it further away from the vehicle. I may also try to check under the fuse box, but I can't see how moisture/ice would get there. While it has been cold, there hasn't been any recent precipitation. Keeping a jump pack in my car for now...
fozzi58
North Jersey
Completely agree with @RoadTrip but I would add 2 ground wires anyway just to be safe. Using some high quality 8 guage wire (Oxygen free copper (OFC) over copper covered aluminum (CCA)) add a ground wire from battery terminal to the body and one from the engine block to the body - preferably 2 different spots. You can use an alternator anchor bolt or something for the engine to body ground. Just make sure it's metal to metal.
How does one pull that fusebox apart ???
Google is a free service but here's a youtube vid on a silverado. Same principles....
Montana _Tahoe
Let me ask you this... Did you buy your truck from a Buy here pay here dealer? If so look for the GPS tracker and the kill switch they install along with it. I had one on my Tahoe that killed my battery every 3 days if I wasn't driving it. If the kill switch was wired in incorrectly it will put a constant drain on the battery.
Roux
I have a 2019 Tahoe 5.3 LT. When the truck is off and the temperature outside 30° and below the steering wheel lights light up and then the infotainment screen illumitaes grey and then goes out. 3 minutes later the same thing, steering wheel lights up then the radio screen grey and then goes out. The colder it gets the more it happens. This eventually continues all night till the battery is dead. I have to start the truck every 2 hours or the battery dies. When its warm its fine no issues all summer. As soon as the temp drops below freezing this happens. Help is appreciated
Are you getting these batteries from the same place? Maybe a bad batch? I had a similar situation, but mine ended up being several bad cells within the battery. (had to crank the Yukon every 2 days to remain charged). Would insulating the battery help?
2019Tahoe
2019Tahoe
No it was a certified pre owned with 24,000 miles on it.
2019Tahoe
2019Tahoe
No the battery that was in it when i got it was new, ive bought 1 from autozone and the last 2 is from napa. What causes the steering wheel lights to come on then off and right after that the radio lights up grey and goes out. If i start the truck and warm it up it want happen again till the trucks cold. It has to be warm
Biscuit mobile
I'm chasing almost the same issue on a 2017 Yukon XL Denali. I have a 7.34 amp draw on the battery, measured on the negative cable . The car will pick up my cell phone and connect sometimes when I'm walking 15' away from it and it's locked. The main screen will light up dark grey. The door lock buttons will not work from the inside. The fob works, the outside works and the auto lock in drive work. Passenger side dash fuse box has #39 the 110v outlet draws 3.94 amps. #29 Radio draws 1.7amps. #28 USB/OBS DET draws 0.8a/0.0a Drivers fuse panel #39 ICP 1.1 amp. Now the big questions are: How do I make these circuits go to sleep? Have you checked your fuses for millivolt draw to see what is not sleeping? I know it's time to see what these circuits have in common but how do I know what to replace when I find the common parts. Which part can keep the others awake?
DSLmag
