2019 Tahoe PPV Wheels on my 2011 Tahoe PPV
mmcreynolds
Anyone know if PPV wheels from a 2019 Tahoe PPV (spoke type) would fit my 2011 Tahoe PPV (8 hole)? Both 17 inch and the tires are the
same size, but my research says the offset is different.
B-train
I'd be willing to wager a couple mm of offset won't hurt a thing. I've run 2008 wheels on a 2017, and the same GM accessory wheels on both years without any problem.
You can also go to hubcaphaven.com
This site lists all wheels for all models and years with complete specs.
I could be wrong, but they should fit I put 2018 wheels on my 2003 (not ppv) but I don't think they changed anything until 2022, then they did for sure on the pickups.
if there are tpms sensors those may not work, you might have to buy new ones or swap them out.
others should chime in to verify or deny wheel compatibility.
mmcreynolds
mmcreynolds
Thanks! I found a deal on a mounted and balanced set with nice Goodyear's for less that four new Goodyear's.
mmcreynolds
mmcreynolds
On another note, what are you all running for fuel? It's flex fuel of course. My opinion has always been more octane is better, I also have ethanol free available here
in GA. All stock.
PPV_2018
Senior Member
U.S.A.
Years ago i bought factory take offs from a 2018 silverado and put them on my ‘03. they are exactly the same as my ppv rims just with different center caps. You will be fine.
Really i want to find some 2021+ ppv rims for my truck. They look so good when put on the earlier models.
B-train
in GA. All stock.
It all comes down to cost vs benefit. I love running it in my non-flex 2008 Denali - approx 25 to 30% blend. If the math works out price per mile in the favor of Ethanol, I would run that personally
haileyds
