You are correctIt checks for a signal from time to time and if it doesn’t get one, guess what? The light comes back on. It’s the same as the batteries in your sensors going dead.
It’s probably going back to the last learned pressure. I’d be willing to bet that if you let air out of a tire the readings wouldn’t change. It will eventually fail completely imo.Got in my ride and light was off, had psi on all four corners. After several miles light came back on and psi was dash lines on all four corners. Light stayed on for three or four days and today it was back off with tire psi on all corners.
I agree with this.It’s probably going back to the last learned pressure. I’d be willing to bet that if you let air out of a tire the readings wouldn’t change. It will eventually fail completely imo.
